Locking hub problem...
Old Aug 8, 2004 | 03:43 PM
yoda's Avatar
yoda
OK the cap screws on my super-winch locking hubs are frozen I got
2 out and stripped the rest so how do I get them OUT HELP.
P.S the screws are allen head.
Old Aug 8, 2004 | 08:10 PM
FordPerf300's Avatar
FordPerf300
CAREFULLY drill the heads out and pull the cap off, you should beable to grab the rest of the protruding screw with locking pliers. Add some anti seize on the new cap screws.
Old Aug 8, 2004 | 09:17 PM
fordw60s's Avatar
fordw60s
if the head is stripped and not the screw it self, just get a torx bit that is slightly too big for the allen hole. then tap the bit in to the screw then you will be able to un screw the screws and not destroy the screws. all you will have to do is use the torx bit from now on and they will grip better also.
