you may want to look at a wagoneer then 74thru 76 had flattops and 44 fronts and about 61 wms and some i believe in those years had small bearing spindles which helps in swapping frpm 6 lug to 5 if needed
I knew about Wagoneer axles but around here they are kind of expensive, and I already had a set of Bronco axles. If anyone knows of anything other than scout axles that are close to the width I want feel free to share.
another alternative if you have a shop or someone who does is get a chevy front 44 and cut the long side down its pretty easy to do . there cheap and plentiful
