Weather Striping
I just finished this job on the drivers side door. I found it easy to start at the bottom since the plastic plugs must line up with the holes. This gave me a good starting point. Make sure you lay it out first and know where the curvey bits line up around the corners.
I glued about 18 inches at a time and made sure to stretch the weather stripping everso slightly to thin it out (may make it easier to close when all finished.)
When I was all done, the door didn't close tightly, but after a few hot days I was able to slam it shut and assume this will get easier with time.
Good Luck
Eric
Good Luck
Eric
