building a 76 4x4
Old Aug 6, 2004 | 02:21 PM
beaker420's Avatar
beaker420
building a 76 4x4
Hey everyone.
I just bought a 76 f100 2wheel driver with a 360. Its got a pretty decent body and thats hard to find in canada. I wanna build a half decent mud truck and use this for my body. Im sure its alot easier to just find a 4x4 frame and stick my body on top but what should I be looking for? I assume I can only use a 70-79 body cause the new ones are narrower. Should I look for a 3/4 ton because I want someone with the front leaf springs so I can lift it easier. Should I look for f100? 150? 250? Any feedback is appreciated. Thanks
Old Aug 6, 2004 | 06:49 PM
eddieburnsii's Avatar
eddieburnsii
the coil spring front end is easy to lift and it gives you more flex and better ride than leaf springs....jmho. a 3/4 ton will have a heavier more sturdy frame and it will have the one ton rearend. i guess it depends on what you plan on doing with the truck. i take my 78 1/2 ton anywhere i wanna go and have only busted the u-joints in the front end and that was from poor maintenance. no other problems to my recolection.
Old Aug 6, 2004 | 09:39 PM
ramboss429's Avatar
ramboss429
I'm in the process of building a '67 Shortbox 2 wheel dig machine into a 4x4. I'm using a '75 F250 chasis. Its pretty straightforward.
Old Aug 6, 2004 | 10:54 PM
beaker420's Avatar
beaker420
Well budget is also an issue too. I figure with leaf springs all around I can just drop the shackles and add a few springs for a nice lift. Are all 250's 3/4ton or what is the difference?
Old Aug 6, 2004 | 11:42 PM
eddieburnsii
all 250's are 3/4 ton as far as i know. they have a one ton rear and half ton front with 8 lug rotors. they average 1 ton and half ton to get 3/4 ton. i put 6" highlift coils on the front of my truck for about 100$
Old Aug 7, 2004 | 08:58 AM
beaker420's Avatar
beaker420
A friend of mine as a 79 3/4 ton and its got the leaf spring front end. You just said 3/4 tons had a 1/2ton front end didnt you? So wouldnt that mean it should have coil spring front? Im confused.
Old Aug 7, 2004 | 09:10 AM
eddieburnsii
sorry to cunfuse you. besides front rotors being 8 lug they also have leaf springs on the f250's. the coils are on the f150.
