Automatic Transmission
Old Aug 6, 2004 | 11:12 AM
Ron Crawford's Avatar
Ron Crawford
Have a 1993 Explorer, need to know what other transmission I can use to swap this out. NON- 4wheel, was told I may be able to use trans from Ranger or Bronco II. Thanks Ron
Old Aug 8, 2004 | 07:54 PM
Bashman's Avatar
Bashman
You can use one from same era Ranger or late version Bronco II. The tranny you have in there is an A4LD, available on both aforementioned vehicles.
Old Aug 8, 2004 | 08:19 PM
thelonerangerxlt's Avatar
thelonerangerxlt
If you find a Ranger, make sure it's a v-6 and not the 2.3L four. Even though both engines used the A4LD, the v-6 was stronger internally (used more discs in the clutch packs IIRC).
Old Aug 8, 2004 | 08:50 PM
Tommy_side's Avatar
Tommy_side
will the one from the 4 still work on a 6 and does it bolt right in say from an 86 ranger
Old Aug 9, 2004 | 10:00 AM
mrshorty's Avatar
mrshorty
Any A4LD from '85 to '94 will "bolt" up. An '86 and '87 A4LD will be lacking the wiring for the 3-4 control solenoid (3-4 shift on these years was vacuum controlled) which will irritate the computer from later models. The 4.0 A4LD is also stronger internally than the earlier 2.9 L A4LD's.
