Pitman arm bolt
Old Aug 5, 2004 | 08:21 PM
nzabka's Avatar
nzabka
Pitman arm bolt
Does anyone know off the top of their heads what size the bolt is that holds the pitman arm to the steering gear box on an '85 2wd f150?
Thanks!
Old Aug 5, 2004 | 08:38 PM
alcan60283's Avatar
alcan60283
yea, i do know. I've tightened it up before. Go to sears and buy an 1 5/16 socket. It will come in 3/4 inch drive. Then get an adapter to go from 1/2 inch to 3/4 unless you have 3/4 inch stuff. Then get a breaker bar, or impact of your choice and wrench the HELL out of it ! I believe the torque is something like 200 ft/lbs on that nut. you might want to have another person help you wrench that. Dont wanna scare you now, its very simple, but it takes a lotta strength ! Good luck and have fun.
Old Aug 5, 2004 | 09:13 PM
nzabka's Avatar
nzabka
Thanks alcan60283!
I appreciate it.
