Sensors??
Old Aug 5, 2004 | 05:46 PM
SKaiser1's Avatar
SKaiser1
Sensors??
Took my 7.3 to Ford today, they said I need a speed sensor and a cam sensor. Best place to buy? And of course, how can I replace them myself? They wanted $545 for the cam and $195 for the speed sensor. Sounds a littel steep to me! Help!!
Old Aug 5, 2004 | 06:00 PM
99PSDCREW's Avatar
99PSDCREW
PUHLEASE... Call your friendly local International dealer and ask for the CAMP sensor. About $100 including tax. There are two different ones; you need your engine number to verify which one is correct. My early '99 (built 4/98)took the updated "newer" version, maybe you can work with that. As for the speedsensor, I replaced it but I know it didn't cost that much at the Ford stealership, more like $20.80 as I was just quoted a minute ago.....
Old Aug 5, 2004 | 06:20 PM
SKaiser1's Avatar
SKaiser1
Great, I'll give that a try, I think my manu date is the same, thanks for the help. Are they easy to change?
Old Aug 6, 2004 | 12:05 PM
99PSDCREW's Avatar
99PSDCREW
Speed sensor on top of the rear differential took me 5 minutes with the right socket. Camp sensor, remove the belt to bet better access, disconnect batteries (just in case), 10mm socket and abouit a 2-3 inch extension would do great. Be sure to keep the socket straight on because it's probably in there well and takes a bit to get loose, you don't want to strip it. Reverse install's a piece o' cake. Hope this helps.
Old Aug 6, 2004 | 12:07 PM
johnsdiesel's Avatar
johnsdiesel
Click on my user name and "view public profile." I have 2 links in my signature that have information, part #s, and diagrams of the CMP Sensor.
Old Aug 6, 2004 | 12:12 PM
SKaiser1's Avatar
SKaiser1
Thank you!
I'll give it a try, thanks for your help!
