Recharging my AC
Old Aug 5, 2004 | 05:13 PM
ranger90's Avatar
ranger90
Recharging my AC
I have a 90 Ranger with the 2.3 engine and 147,000 miles on it- got the thing fixed up pretty well over the past month and today I started working on the air conditioning- it looks like the previous AC belt fell apart in there ( pieces of it were everywhere) so I put a new belt on the compressor and crossed my fingers- nothing but hot air when I turned the ac on- I do believe the compressor works though because everytime I turned it on I could feel and hear the engine srain a little.
My question is this: can I just recharge this and it will be fixed? I have an old can of R-12 sitting in the garage - or should I buy one of those kits at autozone to convert it to 134a? I dont know the history of the ac system in this truck- it looks like someone just gave up on it when the belt broke.
Old Aug 5, 2004 | 05:29 PM
Vin 95's Avatar
Vin 95
Thats a judgement call,the R12 is alot more expensive than the 134A, and if you have a leak, then you just wasted alot of money if it leaks out.on the other hand, you might put the can you have in and see if it gets cool at all,although 1 can probably wont be enough to charge it all the way.In the long run your better off converting to 134A because you'll be adding a can every year or so.
Old Aug 5, 2004 | 07:42 PM
Ken00's Avatar
Ken00
Pulling a vacuum on the system should let you know if you have a leak.
