Sponsored by: Kumho
High Pressure Hose
Old Aug 5, 2004 | 04:38 PM
Specialist's Avatar
Specialist
High Pressure Hose
on the power sterring, I have a 97 Expedition with a 4.6. Is there a trick to getting the dang thig out. I can't get the the nut on the pump end.
Old Aug 5, 2004 | 06:05 PM
battered_bronco's Avatar
battered_bronco
flare nut wrench?? got one?
they grip most of the nut
or if gonna trow it any who
cut it with the proper catch pan and use a deep socket git no metal in it
Old Sep 14, 2004 | 03:03 PM
gatesj's Avatar
gatesj
Yep, line wrench and if that doesn't work break off the line, squeezing it off if you can and drive a socket onto it. I just did this on my '95, I had to do it to both fittings on the steering box. This was so rusted I wound up using a tiny bit smaller in metric and driving it on with a hammer to get a real good grip on the line nut. It's a nightmare if you strip them.
Old Sep 23, 2004 | 12:44 AM
battered_bronco
a flare nut wrench worked on my stock line from 1978(if not from 78 it was close) a couple years back
