fuel filter disconnect problem
Old Oct 14, 2001 | 09:49 PM
explorerxlt94's Avatar
explorerxlt94
I have a 94 explorer and have a problem disconnecting the fuel filter. I have the disconnect tool and was able to disconnect the one side closer to the gas tank, but the front connection would not disconnect at all. Is there a solution to this annoying problem?
Justin
Old Oct 14, 2001 | 10:50 PM
PAUL_2's Avatar
PAUL_2
A lot of times you really have to push in hard to release the connecter , It will come off .
Old Oct 14, 2001 | 11:40 PM
explorerxlt94
I spent two hours pushing extremely hard and using a screwdriver to push even harder and also needle nose pliers that I used to get in behind the disconnect tool to push on it. Still no luck. Any ideas on that? I have a few different disconnect tools and i would like to know if there are any more, would anyone know of a place to find more tools?
Justin
Old Oct 15, 2001 | 10:37 PM
douglapd's Avatar
douglapd
Lot's of times, you have to push the line in towards the filter, then insert the disconnect tool to unlock the tabs.
Otherwise when you push the disconnect tool in, it doesn't unlock the tabs.
After you change the filter and push the lines back on, pull on the lines to make sure that the locking tabs are locked. The lines have been known to not lock and come off two-three days later.
Doug
Old Oct 15, 2001 | 10:55 PM
nitro94's Avatar
nitro94
Follow the post on pushing in on the line before trying to pull it off. Works every time for me. On the more tools question. In my opinion Snap On is the only one to buy. I own every different type of fuel line removal tool there is and Snap On's is the best.
2000 XLT Flare Supercab Sport 5.4-Auto-355LS-Tow pkg-Bedrug-Xtang Tonneau
Old Oct 16, 2001 | 05:42 PM
explorerxlt94
Ok i tried pushing the line in towards the fitting and still no good. I did notice though that on the side im having trouble with the tool will not go all the way in to make contact with the fitting to release the spring lock. i compared it to the other fitting and thats the side that will release and come off. i wonder if there is something stuck inside the fitting like a broken disconnect tool holding up the works here.
Justin
Old Oct 16, 2001 | 11:35 PM
PAUL_2's Avatar
PAUL_2
