vibration
Old Oct 2, 2001 | 10:03 AM
spydermandb's Avatar
spydermandb
vibration
i have a vibration from the front end at 65 mph. its 4x4 '91. its not constant however, sometimes at 65 it will run smooth, but most of the time it vibrates. i had all tires relbalanced, front end alignment, and rotors recut, and new brakes in the rear. what else could be the cause of this wierd vibratrion?
Old Oct 4, 2001 | 11:51 AM
dinograd's Avatar
dinograd
vibration
Check out this TSB from Ford regarding vibration:
Make: FORD TRUCK
Service Bulletin Number: 95218
NHTSA Item Number: SB046481
Component: ENGINE:MOUNTS
Summary:
A VIBRATION/SHAKE MAY BE FELT IN THE SEAT AND/OR FLOOR AT SPEEDS ABOVE 50 MPH (80 KM/H) AND PEAKING NEAR 65 MPH (105 KM/H) ON SOME VEHICLES. AN 'AFTER SHAKE' CONDITION MAY ALSO EXIST WHEN DRIVING OVER A BUMP AT SPEEDS LESS THAN 45 MPH (72 KM/H). INSTALL NEW DESIGN LH AND RH ENGINE MOUNTS AND REAR AXLE-TO-FRAME LATERAL SHOCK ABSORBER.
I'm not sure if this will help or not but I have seen other postings about this problem and by adding these mounts it does help. Here is a link to check out:
http://www.glue.umd.edu/~singletn/web/pages/vibs.html
This is one of the best pages I've found on the web for curring ills with Explorers. Good luck!
Old Oct 14, 2001 | 07:46 PM
kornford's Avatar
kornford
vibration
what kind of motor mounts are required and the the part number?
and also what are you talkin about in the laterall shock absorber i have the same problem only mine is 2wd
Old Oct 17, 2001 | 05:25 PM
dinograd's Avatar
dinograd
vibration
I'm not sure of the part numbers. From what I've read you should probably go in to the dealer and see if maybe you can get a hold of the TSB. If not, follow the Recalls/TSBs link on the main page and pay for this particular TSB. The info. I provided is based on just what I've read.
Old Oct 18, 2001 | 11:12 AM
reberhardt's Avatar
reberhardt
vibration
