Bronco II Ford Bronco II
Question??
Old Aug 5, 2004 | 03:08 PM
dogg16's Avatar
dogg16
Question??
will front rotors cause a vibration(shimmy) if they are warped or out of line ???will turning the rotors fix the problem?do you have to do both sides,passenger and drivers side??
Old Aug 5, 2004 | 04:00 PM
Help I M Stuck's Avatar
Help I M Stuck
it will be VERY noticible when u hit the brake..its best to do both sides..new ones arent that expensive...
Old Aug 6, 2004 | 10:13 AM
Bronco Bob's Avatar
Bronco Bob
Warped rotors alone would not cause a vibration (shimmy) if the brakes are not applied. Check ur tire pressure, lug nuts, and then a balance if it's still there.
442john
19
Jun 4, 2014 06:14 AM
Bayer-Z28
Dec 19, 2009 09:06 AM
italstallion2
Apr 8, 2005 08:00 AM
PoolBoy
Jul 4, 2004 04:29 AM
8588ranger
Jan 25, 2004 12:54 PM
