Factory window sticker
Old Oct 24, 2001 | 12:49 AM
drifter's Avatar
drifter
Is there anyplace where I can get a duplicate of the factory window sticker that lists the options that came with my 1998 Explorer? Thanks
Old Oct 31, 2001 | 06:33 PM
totalrecall's Avatar
totalrecall
Try this - it is from ford-diesel.com. I am waiting on my response.
totalrecall
"You can request a build sheet from the Ford Owner Connection. If you haven't signed up, do so and then go to "Contact Us" after you log in and then there will be the option to contact them by e-mail. Then there are several options for e-mail subjects. I used the vehicle-related one. Then in the comment/question/request form, explain that you bought your truck used and that you would like a build sheet. I had a reply within several days.
Since you mentioned the rear end, check out Keith Anderson's article, Identifying Your Rear Differential. This is an easy way to find out what sort of rear end your truck has.
Your VIN sticker on the driver's side door also has some information about your truck. You can look at that and compare some of that to some tables in your owner's manual to learn even more about your truck.
Cheers & I hope this helps!"
Old Nov 1, 2001 | 06:20 PM
Mikeman's Avatar
Mikeman
Walwal44
Jul 5, 2015 06:29 PM
ilbigmike
May 15, 2014 11:15 PM
parnass
Aug 26, 2013 08:19 AM
Daveof Sager Estates
Dec 30, 2010 07:14 PM
srkuck62
Sep 14, 2005 07:40 AM
