Bad Starter??
Old Nov 7, 2001 | 09:42 PM
craig5's Avatar
craig5
Bad Starter??
My 96 explorer has been running great and all of a sudden it would not start. I cranked the key several times and all I heard was one click each time I turned the key. It finally started on the seventh or eighth turn. I drove the car to the parts store and they told me it was probably the silinoid on the drivers side front fender. The car started with the old soilenoid when I was leaving the store with one crank. I replaced the soilenoid when I got home and the problem was back, with the new one. Is it my starter that has gone bad and how do I get to it with only jacks to lift up the vehicle?
Old Nov 8, 2001 | 02:23 PM
Mikeman's Avatar
Mikeman
Bad Starter??
It sounds like you may have a bad spot on the starter. The next time it happens, tap the starter and see if it makes a difference. Before you replace the starter, make sure that the starter and battery cable connections are clean, especially the ground.
Old Nov 8, 2001 | 02:47 PM
soliger's Avatar
soliger
Bad Starter??
Nathan511
Jan 27, 2017 05:18 PM
andyofne
24
Oct 9, 2016 02:58 PM
Jericho111
Modular V8 (4.6L, 5.4L)
May 20, 2015 04:10 PM
rich gill
Sep 9, 2010 08:33 PM
bradleyj
Electrical Systems/Wiring
Nov 12, 2006 08:53 PM
