Sponsored by: Real Truck
Load range E tires
Old Aug 4, 2004 | 09:33 AM
MoparDoug's Avatar
MoparDoug
Load range E tires
Hello all,
It's getting to time for new tires, and I would welcome some suggestions. I have an F250 Crewcab Longbed 4WD, and here is what I am looking for:
Stock size tire; ie, LT265-75/16
Would like an all-terrain style, and don't mind a little extra road noise.
Wet/dry traction are most important.
I like the looks of an aggessive tire on the truck.
I am considering several different tires:
Cooper Discoverer S/T
Big O Bigfoot A/T
Pirelli Scorpion A/T
Nitto Terra Grappler
One tire I cannot consider (unfortunately) is the Bridgestone Dueler A/T, because it is not made in load range E. I really want tires that equal or exceed my axle capacities, as I work the truck with heavy loads in the bed. Any experience or suggestions are appreciated. Thanks.
Old Aug 4, 2004 | 11:21 AM
jjshaw's Avatar
jjshaw
The Bridgestone Revo's do come in 265/75-16 E. I don't have any direct experience with them, but the reviews at the Tire Rack are pretty impressive.
http://www.tirerack.com/tires/tires....ler+A%2FT+Revo
Old Aug 4, 2004 | 11:47 AM
modeler80's Avatar
modeler80
Ok I’m looking for tire as well. What is the difference between E rated and D rated, I’ve noticed on may of the tire specs that a 285/75/16 D in many case will hold as much if not more than a 265/75/16 E is that just because of the larger tire or are some just made stronger?
Thanks
Old Aug 4, 2004 | 12:11 PM
jjshaw's Avatar
jjshaw
Can't quote the specifics to you, but load rating is the combined effect of the max load and max air pressure.
Old Aug 4, 2004 | 01:48 PM
Rob Kosinski's Avatar
Rob Kosinski
I have been extremly happy with the Nitto Tera Grapplers. I have them in 305's and they work great.
RK
Old Aug 4, 2004 | 02:13 PM
Big's Avatar
Big
Revos
JJSHAW is right that the Revos come in LR E and modeler80 is correct as well that the 285s, although LR D, are rated at more weight than the LR E in the 265s. I put a set of the 285/75R16s on my 2000 F250 SC SB 4X4. They were EXCELLENT in the wet. Not so good in the mud but that is why God made 4X4s. They didn't ride as good as the Steeltex that came on the truck but I figured that was because of the bigger tire size among other things. They really started to thump and vibrate when I had about 50k+ miles on them. I kept them rotated every 5k and they wore really well.
My newer truck is a 2003 F350 CC LB 4X4 and the previous owner had put Pirelli STRas on it. They are a really nice riding tire compared to the REVOs (understanding that the '03 is a lot longer and has a 6.0L up front vs. short bed and the 5.4 in the '00). I can't say weather or not the Pirellis have as good wet weather traction cuz the 6.0 will smoke the tires on dry pavement let alone when it is wet. All I can say is I like the Pirellis now, but I will go with a Michellin LTX M/S when these tires are due to be replaced. Hopefully that will be another year or 20k or so.
Old Aug 4, 2004 | 03:26 PM
ColtM4's Avatar
ColtM4
I love my Nitto TerraGrapplers, good traction and very quiet considering how they look like noisy tires.
Old Aug 4, 2004 | 05:56 PM
furgburg's Avatar
furgburg
MOPARDOUG, I have a set of 4 Pirelli Scorpians with only about 300 miles on them when I took them off. They are like new. Im in MI so I dont know about shipping costs. If interested let me know
Old Aug 6, 2004 | 05:20 AM
rockyrider's Avatar
rockyrider
I have a set of four LT255x85x16r Dunlop Radial Mud Rovers for sale. They have aprox 3000 miles on them. Cost $150 ea new, I'll take $325 for the set. Email for pics if interested. bayhorses@yahoo.com
Old Aug 6, 2004 | 12:32 PM
Edmo's Avatar
Edmo
The D range tires are 8 ply while the E range tires are 10 ply...
The extra 2 plys make for a little tougher tire. Any others out there smart on the 8 vs 10 ply subject?
Edmo
Old Aug 6, 2004 | 10:31 PM
99f350sd's Avatar
99f350sd
I like the Revo's alot. I got the d's but they do make e's.
Old Aug 11, 2004 | 04:48 PM
indiancreekracing's Avatar
indiancreekracing
Here is a new tire just out...
Dunlop Radial Rover RV XT you can find them at discounttiredirect.com
check them out
I just bought some for my 01 diesel 4wd crewcab in the 265/75/16 load E for $116/ea DELIVERED
Old Aug 11, 2004 | 08:56 PM
Edmo's Avatar
Edmo
They are putting Revo 285/75R16s "Ds" on my truck tommorrow... I'm looking forward to the slightly bigger tires and better performance over my factory Steeltex R4S's.
You can get the Revo in an E range if you chose the 265/75R16s, however the 285s only come in a D.
I think it is a function of weight capacities. My factory 265 Es were rated for 3,415 lbs at 70 PSI and the 285 Ds are rated for 3,305 lbs at 65 PSI. Since the 285s are only 110 lbs less in rated capacity, they elected to stick with 8 plys and the lower max pressure while achieving a close match in weight rating.
Bigger tires will fill my 4x4's wheel wells better, but several things will suffer... First the actual vs indicated speed will change (mine is currently off and will actually get better); the rear gear ratio will drop (I've got the lowest factory 4.30 gears so I should be OK); and lastly the tires are bigger, thus they will not do as well on MPG.
More to come on the Revos after they are installed. I tow a 8,000 lb travel trailer and will update you on the Revos performance while towing.
Edmo
Old Aug 12, 2004 | 11:53 AM
DShira's Avatar
DShira
Edmo
Bigger tires should do a tiny bit better on MPG Lower rpm at same speed as a smaller tire should use a bit less fuel...
Old Aug 12, 2004 | 02:48 PM
Big's Avatar
Big
I noticed that my mpgs dropped with the bigger tires. That is even counting the slight difference in wheel rollout (circumfrence). I think the tires are a bit heavier and rotating mass really is tough to overcome. I am an amateur bicycle racer and rotating mass means a lot to us freaks.
Another thing about the REVOs I had on my truck (285/75-R16s) is that they were a little rougher when new and a LOT rougher ride when older. If I hadn't gotten rid of the truck (traded up) I would have dumped them even to go back with the crappy Steeltex tires. (Actually I would have dropped some coin on Michellin LTX M/Ss)
The REVOs are good tires and looked really good in that size on my truck. They are EXCELLENT in the wet too. I just didn't like them the older they got.
PS I was really **** about keeping MPG stats when I saw the drop (1 mpg or so).
Big
PPS I see I need to update my sig. stay tuned...(as if you care!)
