What spark plug do you suggest?
At idle to just touching the gas letting it pull away it seems a little rough to me by feel. Also if I rev the engine from idle in park to about 2500 it revs fine but when you let off of it the engine seems to sputter then idle back down. So I think I will change the plugs and see how this helps. I have some bosch plat 4's I bought a while back because I had such good luck with them in a Jeep and my Mustang I race. I hear such bad things about them in the 5.4 I think I will just let them set, it has been too long to return them.
So what plug should I buy to replace the stock plugs with?
Should I expect any difference after the change, or should I change the IAC at the same time?
I have owned the truck for almost 40k miles now and have always gotten the same gas milage around 11-12 in town and 13-14 on the highway. It has 265/70/16's on it and came factory 255's so I don't know how far that throughs my calculators numbers off when dividing out my gallons and my trip odometer. I am hoping this plug change brings me up to 13 in town and 15-16 on the highway.
Thanks for any help,
Rod
I would also check for vacuum leaks and try cleaning the IAC.
You'll find lots of info on doing both of those if you do a search here.
