motor cleaning
Old Aug 3, 2004 | 09:32 PM
RickyBR's Avatar
RickyBR
Question motor cleaning
can anyone give any good advice on degreasing and or preasure washing a 7.3 PSD motor? What all to cover or avoid spraying directly against.
Old Aug 3, 2004 | 10:06 PM
Fire Rooster's Avatar
Fire Rooster
good old fashion steam cleaning.
Fire rooster
Old Aug 3, 2004 | 10:12 PM
farmb0y's Avatar
farmb0y
I would advice against pressure washing the engine. There's a lot of seals and gaskets that could get blown out, even if you aren't spraying at them directly. I've been working on mine trying to clean it up and about the safest way is just degreasing it. I'm using Simple Green and a rag and just wiping all it clean. Just have to make sure that Simple Green isn't corrosive for certain parts.
Old Aug 4, 2004 | 03:22 AM
The Grinch's Avatar
The Grinch
I just wipe down the motor after washing the exterior. Keep up on this and it stays pretty clean. Then you don't need to do anything else. But if it is dirty, then I would got the Simple Green route too.
Old Aug 4, 2004 | 06:09 AM
herndo's Avatar
herndo
Cleaning a 7.3
So it's advised not to use water to rinse after you apply a decreaser?
Thanks for any input.
Old Aug 4, 2004 | 06:20 AM
International Tech's Avatar
International Tech
as long as the air box is sealed steam clean away. If it isnt, cover it then steam clean it. Weve been steam cleaning engines for years after a repair and never had a problem.
Old Aug 4, 2004 | 07:33 AM
majorpecs's Avatar
majorpecs
How exactly do you steam clean an engine?
Old Aug 4, 2004 | 03:21 PM
shendoa's Avatar
shendoa
what i do is go to napa, get gunk engine brite - spray engine let stand 15 minutes, then rinse with garden hose, make shure you cover the intake good. watter don't compress = in piston.
Old Aug 6, 2004 | 11:01 AM
RickyBR's Avatar
RickyBR
can steam cleaners be rented reasonably anywhere, or would I be better off purchasing one?
