Sponsored by: Auxito
Howling on acceleration
Old Aug 3, 2004 | 08:28 PM
aerostargal's Avatar
aerostargal
Question Howling on acceleration
Hi All,
Our 97 F150 SC 4x4 4.6L V8 has a weird "howling" sound only on acceleration. It stops as soon as we let off the gas.
This truck has 140K on the clock and the howling started around 137K. We have no history on it since we purchased it from an auction resaler in November 2003.
Just had it in to our mechanic who said the differential had no fluid at all. He fixed it up (additive and all), but we still get that howling sound.
What the heck causes that noise? Any advice or insight would be greatly appreciated!
TIA
aerostargal
Old Aug 3, 2004 | 08:37 PM
Racerguy's Avatar
Racerguy
You probably have bad pinion bearings. I've replaced quite a few of these for the same problem. Unfortunately it usually means pretty much overhauling the whole rear diff.
Old Aug 3, 2004 | 10:32 PM
Bikeitswift's Avatar
Bikeitswift
Mine's a whine...
I just picked up an early 97 F150 2WD with 26,400 miles on it (little old man's truck!). I have the back seay reat removed to do some quarter panel body work, and because of that I can really hear the road noise through the cabin vents that open up when the AC is taken of "Max" and put on another setting. When doing so, I hear a high pitched whine when accelerating or under load...faint, but seems louder after the truck is driven about 40 miles or so. I assumed this was coming from the transmission, but might it be the pinion bearings as well?? Sure not many miles for that sort of stuff to happen...but if its my transmission (auto OD), what;s up with that? b After 100 miles, I can clearly hear it when I have the windows down in town and take off from a stop.
Old Aug 4, 2004 | 12:26 AM
Racerguy's Avatar
Racerguy
I've seen some with low miles have bad bearings too.
Usually the noise will be there either under acceleration or deccel but not both if its the bearings.
At low speed when taking off the noise you hear is probably planetary gear noise in the transmission and is nothing to worry about unless it gets really loud.
Old Aug 4, 2004 | 08:19 AM
aerostargal
Thanks Racerguy. Any idea how much it might cost to have the rear diff overhauled? The service center we take our trucks to charges $58/hr labor and a minimal mark-up on parts.
Old Aug 4, 2004 | 08:38 AM
Racerguy's Avatar
Racerguy
No, I dont know how much it would cost. I dont normally see the prices on most jobs...I just do the work
And I'm in Canada so our prices will be different.
I would get your mechanic to check and see what it needs and get a quote. You might want to get a couple quotes to make sure it's in the ballpark.
Old Aug 4, 2004 | 04:57 PM
aerostargal
Thanks AGAIN racerguy! You are a wealth of information! (Even if you don't have U.S. estimates on service costs
Old Aug 4, 2004 | 05:04 PM
Racerguy's Avatar
Racerguy
I was gonna say something about US vs Canadian prices but I dont think I want to start that
Let us know what you find with it.
Old Aug 4, 2004 | 07:19 PM
OE812's Avatar
OE812
8th Gear
Originally Posted by aerostargal
"howling" sound only on acceleration. It stops as soon as we let off the gas. . .
Check the fan clutch WITH THE ENGINE OFF. It should spin freely.
Jeff
Steve_250
Jun 14, 2016 11:13 AM
SuperDutyScaler
Sep 9, 2015 05:08 PM
motopsyko32
May 30, 2012 06:40 AM
sconut1
Apr 15, 2007 07:03 AM
aerostargal
Aerostar
15
Dec 10, 2003 12:02 PM
