02 sensers????
Old Aug 3, 2004 | 04:35 PM
I SHO OFF's Avatar
I SHO OFF
Question 02 sensers????
Been reading up on this till my eyes hurt still have ????s. I have a 96 5.8 with true duals. The truck came with 3 o2 sensers, 2 b/4 cats 1 after; put duals on when warranty expired. I put on 2.5" with glass packs no cats left rear o2 off, the check engine light came on (so what) and I drove it like that for 3-4 years. It didnt run bad but after moving to the city I want to quiet it down and the next time I get it inspected I have to run the admissions test (February). The check engine light is still on and it's not running very well. It seems to want to sputter at mid-rpm. I changed the fuel filter, which helped a little. I put a dual inlet/dual outlet hi-flow cat on, but still didn't put the third 02 sensor on (b/c the wire is not long enough). Can I just make the wire longer? Would that fix my problem or could it be something else?
Old Aug 4, 2004 | 05:12 AM
V10man's Avatar
V10man
The 3rd O2 sensor checks the working condition of the cat. Since you have none it threw the CEL. You either have to reinstall the sensor or find a device that plugs into the wire and simulates a sensor. I think you will have a hard time passing the test.
Old Aug 4, 2004 | 05:20 AM
I SHO OFF's Avatar
I SHO OFF
can i just make the o2 i have longer or do i have to get somthing special?
