Keyless entry
Old Nov 22, 2001 | 06:55 PM
truckie151's Avatar
truckie151
Keyless entry
I just bought a 1995 Explorer XLT with the keypad beside the drivers door handle. Noone has the codes for it and i was wondering where i could look to find the code to use it, or change the code for that matter.
Old Nov 22, 2001 | 09:26 PM
N700MS's Avatar
N700MS
Keyless entry
Congrats on your purchase. I too have an Explorer XLT with the keypad. There should be a card in the owner's manual that has numbers on it. That is the code for the door. You can't change the code unless you know the original code. If you don't have a card, you could try taking it to the dealership and have them try and reprogram. The code might even be in the engine computer. They can check that too. Also, what color do you get it in and do you have autolamp and the overhead console? Mine is white with the lower portion painted. I have autolamp and the overhead console. I love them both. Enjoy your Explorer.
N700MS
P.S. Do you have the V8 and do you have 4x2 or 4x4?
Old Nov 23, 2001 | 09:28 AM
mason's Avatar
mason
Keyless entry
You can find the code on the box located in the jack area. Take the cover off the jack area (driver's side rear) and look for a metal box just in front of the open area. The box will have a 5 digit number on it that will open your doors and allow you to change the code. You will probably need a flashlight to be able to read the code.
Old Nov 23, 2001 | 08:56 PM
truckie151's Avatar
truckie151
Keyless entry
My truck is a 4.0 V6, dark blue in color. It too has the overhead lamp and console.
Thanks i found the right code...
Old Nov 25, 2001 | 01:26 AM
N700MS's Avatar
N700MS
Keyless entry
Funny thing about the overhead console, the manual says that is only avaliable on the Limited model. Odd isn't it? Oh well who cares as long as I have it.
N700MS
Will eventually own:
2003-2005 Ford Ranger XLT w/ 3.0L V6
Old Nov 25, 2001 | 08:01 PM
dinograd's Avatar
dinograd
Keyless entry
