brake lights
Old Sep 30, 2001 | 09:22 PM
calikid's Avatar
calikid
brake lights
I have a 1998 explorer sport. The running lights seem to be fine but all three brake lights dont work. Any ideas.
Old Oct 1, 2001 | 03:12 PM
dinograd's Avatar
dinograd
brake lights
My 94 had the same problem until I fixed it this last weekend. I'll bet if you try the cruise control and push on the brakes that it will slow down but the cruise will not disengage. The problem is the brake stop switch. This is the switch that is connected to the brake pedal to sense when it is pushed, you'll see it under the dash on the top part of the brake pedal. It cost me $10 at NAPA.
To replace it, pull the cotter pin with a pair of needle nose pliers, slide the washer off of the shaft, then slide the switch off. Disconnect the electrical connector, and put in the replacement in reverse order. It took all of a few minutes to do. Good luck!
Old Oct 1, 2001 | 10:05 PM
calikid's Avatar
calikid
brake lights
Thanks that did the trick. Bet that would have been 50.00
at the dealer..
Old Nov 26, 2001 | 11:16 AM
scottopp's Avatar
scottopp
brake lights
My 1999 Explorer Sport had the same problem. Based on your recommendation I replaced the brake light switch for $11.00.
All set-- thanks for your posting!!
Old Nov 26, 2001 | 01:53 PM
billyb's Avatar
billyb
brake lights
