Offroad & 4x4
sas fabrication ?
Old Aug 3, 2004 | 12:33 PM
th0mpson182's Avatar
th0mpson182
sas fabrication ?
ok what pieces are going to have to have to be fabricated for my putting the 77' dana 44 into my 96 bronco, I know it can be done labor wise for about 600 bucks and brakes are prolly another 200 or so but, i was told i was going to prolly have to get that fabritech kit for like $1800 and its like 8 or 9 pieces of metal, excuse me brackets, and they want 1800 dollars for it, i will rip up ttbs all day before giving fabritech that much money for some pieces of metal
Old Aug 3, 2004 | 07:56 PM
ramboss429's Avatar
ramboss429
Do a search on here for SAS and go to Yahoo and do a Solid Axle Swap search on there. Alot of sites will come up with detailed pictures.
When I was planning my SAS on my '92 I was going to use this site for my design
Brian Soderblom's Solid Axle Swap Site
Old Aug 3, 2004 | 08:41 PM
JeremyH's Avatar
JeremyH
Well.......how do you plan on setting up the axle? Coils or leafs? If coils, 3,4 or 5 link?
You might call the guys at www.bluetorchfab.com and see how they can help you.
Old Aug 4, 2004 | 12:50 PM
FordPerf300's Avatar
FordPerf300
You can do the swap with practially 99% stock parts.
What you need:
6" lift or greater coils for 78/79 bronco.
'77 Tierod
90's F350 4x4 draglink
(If the axle has disc brakes) reuse your calipers with 77 brakepads
extended brake lines
'77 trac-bar.
'77 radius arms, brackets, coil pads
7deg c bushings
what you need to make:
tracbar mount, must run parallel to the draglink
for the radius arm brackets you can either cut the face of the bracket and move them in 21deg. Or i have heard of offset degree radius arm bushings.
Old Aug 8, 2004 | 01:12 PM
78f3504x4's Avatar
78f3504x4
I posted my SAS parts list earlier, do a "SAS" search in this forum, and my list is under "jimmydean's" thread. I used 4" 78/79 coils, and they worked perfect. I also have swap pics in my gallery. I've seen about 15-20 different sas for these trucks, and I never saw 2 the same. You'll find a way. Good luck.
breedo99
19
Feb 26, 2016 12:41 PM
rosett
Aerostar
Jul 30, 2012 06:30 PM
WATTSUP!
Jul 8, 2009 11:53 PM
fishmanndotcom
Offroad & 4x4
26
Nov 30, 2004 02:35 PM
BigBoyStone
Offroad & 4x4
Sep 25, 2002 07:17 PM
