Fuel Pump Replaced
Old Aug 3, 2004 | 10:08 AM
daorte's Avatar
daorte
Fuel Pump Replaced
I had to have my fuel pump replaced a week ago. I took my Lariat Screw in to see about having my PCM updated and when they ran some tests they found that I only had about 3 psi coming from the fuel pump. So they replaced it. They never did update the PCM.
Has anyone else had this problem?
Old Aug 3, 2004 | 10:50 AM
gmcplus03's Avatar
gmcplus03
what led them to check your fuel pressure? just curious why they would do that when you were checking the pcm updates.
Old Aug 3, 2004 | 12:15 PM
Dr No's Avatar
Dr No
The engine won't run on 3 lbs fuel psi. It needs 40 lbs.Was your truck towed to the shop
Mike
Midwest Dually
1983 - 2012 Ranger & B-Series
Sep 26, 2011 10:26 PM
CRAZYC123
Aug 26, 2011 10:02 PM
Chief150
Oct 19, 2010 08:00 AM
hlozano
6.4L Power Stroke Diesel
Sep 28, 2010 09:46 AM
MFD606
Mar 5, 2009 11:38 PM
