What do I do?
Old Aug 3, 2004 | 01:15 AM
Judah's Avatar
Judah
Question What do I do?
My problem is that when I turn my (97'Expedition) steering wheel it makes A annoying squeeking sound. I hate it, its kind of embarrising. I heard from a friend that this happens to a lot of Fords. I also heard that there is a oil or a grease of some type that could be injected into the steering boot to solve this problem. Is this true? And what type of lubricant, oil, or grease I should use? How do I apply it? please help...Thanks.
Old Aug 3, 2004 | 11:05 AM
Bornzo's Avatar
Bornzo
Judah,
It sounds like it could be either the serpentine belt or the power steering pump. Have you checked the fluid level in the power steering pump. I would check the level.
Old Aug 3, 2004 | 11:17 AM
ExpyBob's Avatar
ExpyBob
The pitman arm squeaks in these things because you can't lube them.
It's a common problem.
Do a search on pitman arms---Bob.
