timing problems 351 w
Old Aug 3, 2004 | 01:14 AM
351f150texaswindsor's Avatar
351f150texaswindsor
Exclamation timing problems 351 w
I am trying to findout the stock timing degree for a 351w in an 84 f-150 but the engine year is unknown how can I time it properly.
thanks
Old Aug 3, 2004 | 11:23 AM
Kemicalburns's Avatar
Kemicalburns
timing should be 10* btdc , get a timing light it will make things easier .
Old Aug 3, 2004 | 11:29 AM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
When you set the curb idle, make sure you pull off and plug the vaccuum line when you set it. 10-12 btdc should be fine. Or you can play it by ear and turn it till it sounds bad one way, then the other, and settle somewhere in the middle, a little advanced. But a timing light is the best way to go - just don't forget to un-hook and plug the vaccuum advance!
Old Aug 3, 2004 | 11:37 AM
Missileman740's Avatar
Missileman740
My experience with Ford V8's, timing light to get close, then adjust timing so that it starts immediately when you turn the key when warm.
Old Aug 3, 2004 | 03:35 PM
dfisher1's Avatar
dfisher1
All,
Generally speaking, you can pull a valve cover on a Windsor and the year will be cast in the center of the head. Could that help you?
KingFisher
Old Aug 3, 2004 | 11:13 PM
351f150texaswindsor
thanks I will be workin on her.
