timing problems 351 w
Old Aug 3, 2004 | 01:10 AM
351f150texaswindsor's Avatar
351f150texaswindsor
Question timing problems 351 w
I am trying to findout the stock timing degree for a 351w in an 84 f-150 but the engine year is unknown how can I time it properly.
thanks
Old Aug 3, 2004 | 01:30 AM
big hoss 29's Avatar
big hoss 29
Look for an engine calibration code. For example, the code would be something like 4-63H-R00. If you can find that code, you can tell what year your engine is by checking in a Chilton manual. If not, try 10 degrees BTDC. Different years have different settings, but that should get you close. Good luck!
BTW, the calibration code is a sticker somewhere on the engine.
Old Aug 3, 2004 | 09:00 AM
spikedog's Avatar
spikedog
Agree with Big Hoss, 10 degrees is good starting point for stock engine. Make sure you disconnect the vacuum advance while doing the timing. I ran my 351W at 12 degrees with an Edlebrock performer rpm cam.
Tiger57301
Jul 27, 2013 09:00 PM
moneypitf150351w
Aug 11, 2012 06:12 PM
fordjake
Feb 6, 2011 10:45 PM
97redbeastford
1997 - 2003 F150
13
Feb 6, 2008 08:52 PM
Thomsen
15
Feb 19, 2004 12:22 AM
