352 engine
Old Aug 2, 2004 | 09:10 PM
ford390gashog's Avatar
ford390gashog
352 engine
i want to know if i should put new rings on a used engine i am going to buy and if so do i need to bore the walls first
Old Aug 2, 2004 | 09:12 PM
gtex's Avatar
gtex
run a compression check. let us know what you find.
Old Aug 3, 2004 | 08:07 PM
FORD352V8's Avatar
FORD352V8
heck if it needs rings it proably needs everything. Just rebuild it.
Old Aug 3, 2004 | 08:22 PM
rusty70f100's Avatar
rusty70f100
Check the cylinder wall taper. That will tell you if you can get away with a re-ring.
Old Aug 4, 2004 | 12:55 AM
ford390gashog
could i just hone the walls if the bore is fine
Old Aug 4, 2004 | 06:19 AM
baddad457's Avatar
baddad457
If you're gonna rering it, run a glaze-breaker hone thru the bores first.
Old Aug 4, 2004 | 01:27 PM
William's Avatar
William
rusty70f100 has the right answer. Cylinder taper will determine whether you can successfully re-ring without an overbore or not. I sure as heck would not pull a motor and do all that work without a re-build. Basically if it runs good and has compression leave it be.
Old Aug 4, 2004 | 07:06 PM
baddad457's Avatar
baddad457
Well, lets see, I pulled the 390 from my 68 Merc, and all I did was run a glaze breaker through the bores, re ring it along with new bearings, cam, lifters, etc and so far after a year's time. everything's peachy with it, doesn't smoke, burn oil, no excessive blowby. No problems whatsoever, and never once did I check the bore's taper. If it doesn't have a ridge at the bores tops, a re-ring will be fine. Just use cast iron rings or moly faced top rings. No chrome rings--- ever ( don't even know if they even still make em anyway) Pushes the car to mid 14's too.
Old Aug 4, 2004 | 08:31 PM
rusty70f100
Usually you can get away with a re-ring. The only drawback is, the more bore taper you have the quicker the rings will wear out and you'll be back to square one. Ford recommends a maximum of .005" bore taper. I'd say if it's more than .003" get it bored oversize.
