1978 - 1996 Big Bronco
cooling issue in 79 bronco.....
Old Aug 2, 2004 | 05:50 PM
jeffspicoli's Avatar
jeffspicoli
79 bronco with a 400, the engine heats up to normal then gets a tad bit hot...then out of nowhere the needle burys itself all the way up, i have changed thermostat, water pump, fan clutch, and all belts but the problem still persists....any ideas? i was thinking of a new radiator, but that is the last option, TIA, J
Old Aug 2, 2004 | 06:22 PM
BOJOFASO's Avatar
BOJOFASO
have you checked the true temperature with a thermometer? maybe it is not realy getting as hot as you think.
Old Aug 2, 2004 | 08:30 PM
freak98's Avatar
freak98
Try a mechanical gauge.
Old Aug 2, 2004 | 11:11 PM
Fordbronco69's Avatar
Fordbronco69
Infidel
I had the same problem, i had an air pocket in the water jacket of the block, flused the cooling system and refilled and it droped about 50 degress (230F-to-180F) at idle. Also try putting on a better fan. Flex-a-fan makes some cool looking ones and they do work better without that clutch. You will need a fan spacer to go with it if u buy it separate, should run you about 60 bucks all together.
