Fuel Filter Tool?
Old Aug 2, 2004 | 02:27 PM
TX_F4OxR4D's Avatar
TX_F4OxR4D
Fuel Filter Tool?
This may be a dumb question. Forgive my ignorance, but what tool does everyone use to change their fuel filter? Especially, the one under the cab. Does Ford make something that I can buy to make it easier? Thanks.
Brandon
Old Aug 2, 2004 | 02:30 PM
jdadamsjr's Avatar
jdadamsjr
36 mm socket fits it...
some have used an oil filter strap too...
Old Aug 2, 2004 | 03:14 PM
SBV45's Avatar
SBV45
Brandon
That would be against Ford policy....
It's a 36mm socket. If you have a 4X4 with the skid plate you want to use the ratchet with a flex head. A good oil filter wrench could work. Easy? no way.
Old Aug 2, 2004 | 04:04 PM
Blackie60's Avatar
Blackie60
I use 36MM short socket with 1/2 inch rachet and it work pretty good and if you have patient to let it drain slowly then you will be alright as others have said they got fuel soak all over them and I didn't. It was not that hard as I first thought and of course not easy. Did change mine last week for first time and no water in fuel or lite the water in fuel light on on the dash.
Old Aug 2, 2004 | 04:05 PM
jdadamsjr's Avatar
jdadamsjr
Park your truck downhill and pull the 6mm drain plug first..
