3 speed driveshaft question....
Old Aug 2, 2004 | 12:41 PM
78f250lj's Avatar
78f250lj
Question 3 speed driveshaft question....
Hello Everyone!!!
I have a 75 F150 with a 300 3spd column shift and it has a 2-piece driveshaft (has the center carrier bearing in it).
I went to the junkyard today and saw a 76 F100 with a 300 3spd and it had a 1 piece driveshaft.....
Which is correct for my truck? Reason I ask is my 2 piece will need a rebuild, but I have an extra one piece driveshaft from a 79 F150 351M C6. Should I go over my 2 piece or should I just put the one piece in and forget about it??
Thanks!!!!!!!!!!
Lenny
Old Aug 2, 2004 | 01:38 PM
fordflaresides's Avatar
fordflaresides
Are they both shortbeds, if it's a shortbed I don't see the need for a carrier bearing.
Old Aug 2, 2004 | 03:25 PM
Jimbare's Avatar
Jimbare
all alone in the world
there were several lengths of trans used in the 70s, as long as the shaft wont be more than 72 inches long you can use a straight driveline. only thing you will have to do is remove the carrier bearing bracket, it will rub on the straight shaft if you put a load on it.
you can measure from the weld on the rear of the rear shaft to the weld on the front of the front shaft and subtract 2 inches to get the correct length of shaft you will need.
jim
Old Aug 2, 2004 | 03:39 PM
Big Orn's Avatar
Big Orn
I had a '76 longbed with a single driveshaft. Never gave me any trouble.
If the single will fit, go for it.
Old Aug 2, 2004 | 05:17 PM
78f250lj's Avatar
78f250lj
It is a long Bed, I think I will use the original 2 piece, as it has a slip joint on it and the trans dont.
