Codes - 2 or 3 digit?
Old Aug 2, 2004 | 10:50 AM
Evill Ed's Avatar
Evill Ed
I have a 1993 F150 with a 5.0L (302) Does this use 2 or 3 digit codes?
Using a code reader, beeps and blinking light, I get what I think are 2 digit codes, 31 and 34. The book that came with the tool shows 2 digit codes for my year, is this right?
The problem is a high idle, 1100 rpm that cylces up and down ~100 rpm. Also a slight surging during cruise.
I replaced the TPS a few weeks ago, with a new one. Mine is the non adjustable type.
I cleaned the throttle body, AIC and EGR with cleaner, that all seem to move freely.
Any tips?
Thanks,
Ed
Old Aug 2, 2004 | 01:02 PM
acerockola77's Avatar
acerockola77
Both, there is two and three diget codes. Here's a full list of them http://www.broncodata.com/tech/codes.htm
Old Aug 2, 2004 | 04:18 PM
EPNCSU2006's Avatar
EPNCSU2006
It will use one or the other, but not both 2 digit and 3 digit. If the code reader is spitting out two digit codes, then that's what I would assume the computer is blinking out.
Old Aug 3, 2004 | 06:09 AM
blackflareside's Avatar
blackflareside
Thanks, it is definitely 2-digit codes, 31 and 34.
Ed
Old Aug 3, 2004 | 09:21 AM
Huntsman's Avatar
Huntsman
I chased the high idle for two weeks, mine did turn out to be a dirty throttle body, but other likely causes can be a vacuum leak.
Old Aug 3, 2004 | 10:02 AM
Evill Ed's Avatar
Evill Ed
I cleaned the Throttle Body, EGR Valve and Idle Control Valve. I checked for vacuum leaks but can't find any.
I did the KOEO test this morning, get 11 and then 31 and 34 in the stored memory.
The KOER test gives me a 13, (cannot control idle during low test).
I'm pretty sure the problem is with the TPS. I will check the voltage tonight. My is the non adjustable type. What do you do if the voltage is off? How do you adjust it?
BTW- how do you clear the stored codes from the memory?
thanks,
Ed
jnobles06
Aug 25, 2018 04:19 PM
d_stange
May 28, 2017 11:55 AM
JohnMcD348
1978 - 1996 Big Bronco
Jul 19, 2010 04:46 PM
greystreak92
Apr 28, 2005 07:17 PM
Beachbumcook
May 29, 2004 04:53 PM
