Bronco II Ford Bronco II
power doors
Old Aug 1, 2004 | 08:05 PM
Hushmoons's Avatar
Hushmoons
power doors
i would like to just have the windows work not real interested in the locks working. theres a harness of 8 wires in the plug. black , red , blue/black, yellow/black pink/orange,pink/yellow , pink/black, red maybe just a few jumpers and a power supply but where should I start?
Old Aug 2, 2004 | 02:08 PM
Help I M Stuck's Avatar
Help I M Stuck
the junkyard..you will need the wire harness, switch, and whatever power motor/regulator is in the door that raises the window..might even need the tracking inside the door. sounds like a project..all that just for power windows
If you're saying you have power windows and they don't work..then it's probably the regulator inside the door that went bad..trip to the junkyard..$8.00 at a pull it yourself yard around here.
