Which Heads to use?????
Old Aug 1, 2004 | 02:55 PM
53flathead's Avatar
53flathead
I have 2 sets of FE heads, one with casting C6AE-R, and one with D2TE-AA. Which head will be better suited for a 390 performance build in my 2wd 67 F-100? I know I'm going to have to spend some money on either set, so Edelbrock's aren't out of the question either. This truck will NOT be a daily driver, but I want to be able to run on 93 octane pump gas. What kind of mods will be required to get these stock heads close to the e-brock performance? Thanks again for your input.
Old Aug 1, 2004 | 04:03 PM
Ratsmoker's Avatar
Ratsmoker
You will need extensive porting to get the stock heads up to par with the edels. It is cheaper to just buy the edels unless you are a very experienced porter. The edelbrock heads can be ported to flow well beyond the capabilities of the 427 HR, TP, or cammer heads.
Old Aug 3, 2004 | 01:24 AM
BB's Avatar
BB
The C6AE-R's are a much better starting point for your application but I agree with Sean. The C6's don't need a lot of porting but by the time you add the costs of rebuilding the heads along with bigger valves, you're at the Edelbrock level. Plus you get aluminum heads which will help with your octane requirements.
68Ford4Life
15
Nov 20, 2011 08:21 PM
LedheadELH
35
Nov 1, 2006 06:52 PM
390fe
19
Sep 1, 2006 01:29 PM
bigal72
Sep 15, 2000 09:35 PM
Hollis
Oct 10, 1999 04:51 PM
