Manual transmission swapping
Old Aug 1, 2004 | 09:51 AM
sloop's Avatar
sloop
I have a 1973 F100 that came with a 360 and column-shifted 3speed. I pulled the engine and tranny. From what little bit of info I could find about ID'ing these transmissions, I am guessing I have the Ford 3.03, because it has the ford logo stamped on it.
I am planning to go the junkyard today and want to look for a 4 speed replacement transmission.. Will any other tranny from a 1970s/1980s Ford truck bolt up to my bellhousing? Or would I need to find a 4 speed tranny with bellhousing from a FE engine?
thanks
Old Aug 1, 2004 | 12:02 PM
teds74ford's Avatar
teds74ford
I think you can bolt any tranny to your bellhousing. I would measure to be sure, or even better, take the bellhousing with and test fit it on the tranny you look at buying. Ted
Old Aug 1, 2004 | 02:23 PM
85e150's Avatar
85e150
Check out these links. And look some more on this series of threads. Lots of discussion about what fits for your application.
If your 3 gear is a top-loading box, all synchro, it's a 303. Top-loader 4 speed car tranny and top loading 4 speed OD truck trannys will fit--but you have to make sure on input shaft spline, length etc. I think I saw here where truck bellhousing are deeper than cars......
Anyway, check these out:
Or http://www.ttcautomotive.com/Englis...ts/T-56.asp#Car
or http://www.ultrastang.com/Ultrainfo.asp?Page_ID=4
or http://www.motivegear.com/tech_info...anny_guide.html
or http://www.4speedtoploaders.com/
If you want info, this should much of and and the other postings will help.
Old Aug 1, 2004 | 02:53 PM
sloop's Avatar
sloop
My original 3spd is toploading. Here is a picture of it:
It has a Ford logo stamped on it, so that is why I thought it might be a 3.03
Old Aug 6, 2004 | 06:48 PM
85e150's Avatar
85e150
Looks like the one out of my '65 Mustang.... all synchro 303
