91 Power Windows Super SLOW????
Old Jan 4, 2002 | 01:25 PM
jimsanders's Avatar
jimsanders
Post 91 Power Windows Super SLOW????
My 91 Explorer has developed problems with the power windows: The passenger front window will roll down but will not go back up. And, the two rear windows work up and down but go amazingly slow. The driver (most often used) works fine. This leads me to believe that the others don't work well due to lack of use and maybe there is something I can do to clean or lubricate them so they will work better as opposed to replacing the motors. If anyone has any experience with this problem and can give me some advice I would be most thankful.
Jim
Old Jan 4, 2002 | 11:40 PM
nitro94's Avatar
nitro94
I have a spray can of lube (white lithium-spelling?) that I feed down the edges of the glass into the guides that will sometimes work without having to remove the panels for axcess to the tracts. For the one that doesnt go back up, if there isn't a power problem this usually will be a bad gear set in the window motor.
Old Jan 4, 2002 | 11:57 PM
ford94150's Avatar
ford94150
