General Automotive Discussion
Question about Tuned port injection
Old Jul 31, 2004 | 07:26 PM
drewcoolness99's Avatar
drewcoolness99
theres a guy next door with a camaro with an LS1 in it. He says that you don't have to set initial timing. Just set it to 0 and the computer does the rest. I said you have to set the initial timing then the computer handles the advance. Hes running all msd ignition. Whos right?
Old Jul 31, 2004 | 08:56 PM
FordLariat's Avatar
FordLariat
You should be able to set it to 0 and the computer will set the timing automatically. If you have an aftermarket chip, you may have to set the initial timing.
Old Jul 31, 2004 | 11:54 PM
benwantland's Avatar
benwantland
I don't think an LS1 even has a distributor... there is no timing to set, it has individual coils for each plug.
But are we talking about an LS1 for sure? You're mixing a couple of GM engine nomenclatures -
Tuned Port Injection (TPI) - Common name for 80's-92 first gen multiport FI
LT1 - The next camaro and corvette engine, used distributor driven off of cam, made from approximately 92- 97
LS1 - All new small block, plastic intake manifold, coil-on-plug ignition, used from 97 up in vettes, 98 up in camaros
Old Aug 1, 2004 | 08:20 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Moved to General Automotive Discussion
Old Aug 1, 2004 | 09:15 AM
jaydez's Avatar
jaydez
TPI and the LS1 are 2 different things. the LS1 is a DIS so it has no way to se the timming unless you have a tech2 tool.
the TPI does have a base timing that you set at 0 degrese advance.
Old Aug 1, 2004 | 12:18 PM
drewcoolness99
it's not an LS1 i heard someone say it was, but its not.
tempest411
24
Jun 5, 2025 11:11 PM
sibernut
Jan 22, 2016 05:13 AM
lee
Aug 3, 2015 11:30 AM
gtex
18
Oct 14, 2003 09:54 PM
inliner
Mar 26, 2002 12:37 AM
