no power
Old Jul 31, 2004 | 05:32 PM
a1jfjf98's Avatar
a1jfjf98
Angry no power
i have a2000f150 itcould spin tires when i frist got it but now it just bogs out andgoes no low end speed any ideas i also tow a fifth wheel need all the power i can get from it almost forgot its a 4.6
Old Aug 1, 2004 | 12:29 PM
95 F150's Avatar
95 F150
I had the same problem on my 95 once, it trurned out to be the o2 sensor.
Old Sep 18, 2004 | 07:29 PM
a1jfjf98's Avatar
a1jfjf98
still having some trouble i would like some more input.but for now can someone tell me where to locate the IAT SENSER on a 2000 ford f 150
Old Sep 18, 2004 | 09:49 PM
Racerguy's Avatar
Racerguy
Hi Leslie and welcome to the forum
How many miles on your truck? How old are the spark plugs? Fuel filter? Ever clean the MAF sensor?
Old Sep 19, 2004 | 09:53 AM
a1jfjf98's Avatar
a1jfjf98
thanks for the reply, the sparks plugs are 2 weeks old and the fuel filter is a month old.i think i may cleaned the maf senser , thats if its located in the air itake tube .the truck as 117000 km about 65000 miles .still would like the location of IAT senser
Old Sep 19, 2004 | 10:25 AM
Racerguy's Avatar
Racerguy
The IAT is in the air intake tube from the air cleaner to the throttle body. It's about half way in between, on the back of the tube.
Old Sep 19, 2004 | 02:52 PM
a1jfjf98's Avatar
a1jfjf98
thanks racerguy for the input, anymore infor on my power loss would be helpfull
Old Sep 21, 2004 | 08:59 PM
LxMan1's Avatar
LxMan1
Clogging cats perhaps?
Old Sep 26, 2004 | 05:56 PM
a1jfjf98's Avatar
a1jfjf98
thinking of lowering the gears in the rearend to help in towing my fifthwheel . my truck is a 2000 f 150 4.6 two wheel drive it currently has
3.55 gears what would be a good drop for towing and highway driving .also what would be a good prce to pay in canada and do you have a phone number
Old Oct 1, 2004 | 08:55 PM
a1jfjf98's Avatar
a1jfjf98
thanks lxman1 , i had them checked at my local ford dealer every thing was fine .seems i,ve checked every thing else guess i have to live with it maybe i.ll lower the rear gears it,s a 2 wheel drive
Old Oct 1, 2004 | 09:41 PM
LxMan1's Avatar
LxMan1
Other than having the injectors cleaned, I really don't know what else to look for since it seems to run fine.
Old Oct 1, 2004 | 11:15 PM
ford390gashog's Avatar
ford390gashog
maybe it is not your engine and maybe it is in the trans mission how many miles have you done a leakdown test and what about a compresson test
Old Oct 3, 2004 | 05:50 PM
a1jfjf98's Avatar
a1jfjf98
perhaps i should check it what would be a good overall average
Old Oct 3, 2004 | 11:21 PM
LxMan1's Avatar
LxMan1
As long as they are all about the same, all should be ok. I would think that over 100psi should be normal.
Old Oct 5, 2004 | 07:03 PM
a1jfjf98's Avatar
a1jfjf98
thanks for the reply,any ideas on the lower gears question .buy the way can a ford dealer change the shift pionts of my transmission or do i need to buy a programmer like hypertech
