I started thinking last night about what4020loaderman said and i must agree with part of what he stated I had the chance to talk with a gentleman a few years back. He worked for a propane distributer and he owned a 80's F250 4x4 with a simular set up on it where you switched from gas to propane and he told me the same thing 4020loaderman said he had had nothing but trouble wit the switch and the valves that opened the gas or propane if I was to do such a swap I would definatly stay away from that kind of setup the ones I was talking about were straight propane fired setups no gas involved also a about 8 years ago a friend bought a 1984 F350 dually delivery truck it had a propane fired 300 straight six in it with over 200,000 miles on the original motor no work do internally my friend decided to put a flatbed on the truck and when he did he changed it back to gas. this truck ran beautifully prior to the gas swap. he only got another 5-6000 miles and blew a rod. it seems that the problem comes more from introducing gas back into the motor than the the propane. maybe someone out there can explain way that is,but I have heard of this on several occations that someone took a truck that ran propane and switched back to gas and the motors don't last long. also a few other things to look at before you make a decision is what do you plan on doing with this truck. remember you'll lose about 2-2.5 feet of the front of your bed for the tank also you have to plan alot further for any trips you wan't to take the truck on I've heard that there are places that you have difficulty finding propane.
My brother ran a 91 dodge B150 van on dual fuel propane/gas for 480,000 kilometers (about 300,000 miles) with no problem then gave it to his kids. I've had an 87 F150 on dual fuel for over 3 years without a hiccup & still going strong! There is about a 10% loss in power but propane costs half the price of gasoline in my area.
ok guys i just bought a holley propane carb with mixer and governor what else would i need what kind of tank could i use a standard 20 lb tank and do i just run a line from the tank to the carb with a electric shutoff in the middle somewhere
gashog- I'd go to those links above and search out their links as well- go to some good places. And post what you learn for those, like me to follow.
Al- Think I'll probably settle around 10.5-1 compression for a dual fuel. WIth the right head set up and cam I think I can pull off a decent 'tween' motor. I'm not sure what block I want to use yet and it will be a process as i want to build most of it myself. Will probably experiment a lot along the way to include hooking it up to my current semi tired 351m that may be a 400. I'm really wondering if i can pull it off with a 400m with the right cam - full of questions at this point and learning soooo much from you guys here.
I am humbled greatly.
Gashog...Do you have a link to some pics of the Holley parts?
Propane is stored in the tank or cylinder in liquid form. In propane only systems, it goes first to a converter (or whatever the proper name is) to be warmed up to convert it to a gaseous state. The heat used comes from the engine coolant that circulates through the converter. Propane vehicles often quit running when the coolant level gets too low & the converter freezes up.
A 20 lb tank is small & would be a PITA to keep refilling. I ran a propane only 1 ton (360 powered) once that had a 260 liter tank & never had to worry about fuel. There's a wide variety of tank configurations available so you can choose any one that suits your vehicle & needs.
AL.
I was stationed at China Lake Ca and we were running propand and CNG on some of our trucks there. The Navy in Sothern CA was required to have a certian number of trucks converted to other means. Most of them were dual fuel. We were alternating tanks fill them both up and run both dry then go fill them up. I believe Schawans runs alternitive fules in most of their trucks. I know the ones in China Lake were propane
Over this winter I have set up my cheby 81 el camino with a 250 inline six and a turbo blowing through a impco 100 carb with a impco model E regulator/converter......
In case you were wondering why I posted this in a Ford fourm.... I have a 71 360 that is scheduled for the same procedure
If anyone needs anymore info or wants to doel out some flamin' let me know
no flame hear- I have my 02 silverado for sale- 2nd best truck i ever owned- maybe third someday i hope. I will be building a 400 for propane soon and then a 360/390 so fill me in with your wisdom especially on how your gonna set up the wind.
So what is it specifically that you are doing- details man details.
What details do you need?.....
My neighbor started getting on me about My El Camino sitting in my yard.....said it was an eyesore....sooooo I decided to fixit up then do a doughnut on his front lawn.....
I started by ripping out the 305 that was in it that I had cooked ,combination of failed temp gauge (stupid cheap Autozone crap) and a ventalated radiator. I replaced the engine with a 165 hp OMC boat motor, same thing as a 250 chevy just with more ponies. I had the head totally redone... With propane you MUST have hardened seats, preferabley inserts. If not the valves will sink out of sight, trust me I know my 71 ford when I took the motor apart the valves had sunk so far that they never truly seated. Anyway, then I found all the automotive manifolds; Including, an Edlebrock intake. I made a pipe to redirect the exhaust back up towards the hood. cosequently the pipe is "surgical stainless steel" that I "liberated" from a milk tank at a dariy.....
The blower is a IHI turbo that I had "spec'ed" out specifically for this application. I chose that one because it had an adjustable integral wastegate I am gonna set the wastegate for 7 psi to start then crank it up to 9 psi.
With that setup I am hoping for 350 to 400 ft-lbs of tourqe. But time will tell on that....
should there be any other questions I'll be here
Phule
1. how did the donut end up looking- or have you gotten that far.
I'll get back to you on the rest!
I took a chunk of straight pipe took it down to the exhaust shop and had it flared then a slightly smaller bit of pipe was swedged out to hold the donut then just put the donut pipe inside teh large pipe to hold it square
on another note... if it were me I would do a single fuel..... on a dual fuel it just seems that the engine will tolerate either fuel but won't run efficently on either of them.... there would just be too many compromises i.e; you can run alot more compression I would stop before 12:1 but certainly up to that. Also you can run more advance, something like 10 degrees more due to propane burning a little slower. I am not sure on exactally how much more, you might have to play with that a little
that is what I have read and had explained to me, your mileage my vary...
Should anybody want to speak to the experts as far as propane or forced induction alternative fuel. These are THE guys.... http://www.lngplants.com/carbturbo.htm http://www.carbturbo.com/
Ask for Eric about conversions.
Ask for David about turbos.
Don't even bother with AK Miller that won't get you anywhere anymore.
And know you all know more about it than I do...other than I will have the only 1981 'Camino w/250 six w/hairdrier on propane.....and it will be the fastest of those too....
