want more lift.....
want more lift.....
Have an 01 F350, had a 6-8in lift when I bought it, and i want to lift it a little more. It seems a little lower in the back, so I was thinking of 3in larger lift blocks in the rear and some 2in blocks in the front (front is all spring lift), with some longer U-bolts. Is this all I'd need to lift it or is there more stuff involved?
You know, there are a couple trains of thought on blocks in the front. I personally don't have much of a problem with them as long as it's done 'right'(as right as front lift blocks could be ). I'll admit I wasn't exactly the brightest bulb on the tree when I put 3 inch CAST ALUMINUM blocks under the front of my 9K lb. pickup (see signature and gallery). But you know, I ran that thing for 15K miles like that...3K with the factory springs, and another 12K with a shackle reversal and I never had a problem with it. I just made sure that the u-bolts were always tight (kind of **** for safety) and that I didn't drive aggressively (corners and braking). I think that I'm going to run 1.5 inch tapered steel blocks in mine when I get some time to tear into it again. Then I'll weld them to the spring perches on the axle to make sure they don't wedge themselves out. Then I'll pull a few leaves out of the rear and add a 3.5 inch tapered block back there.
Cody
Cody
