'97 model 98 CHECK ENGINE LIGHT
Old Jan 12, 2002 | 07:31 AM
lasertom's Avatar
lasertom
I've '97 High Class 4l SOHC with 180000 km.By 60.000 i was change my first cam tensioner, by 120.000 the second )) but i see its happend oft in this car.Now I've another problem. When I start the motor (sometimes) my RPM goes to 1000 RPM then goes down und then up , sometimes , when I put the gear motor stops..... My CHECK ENGINE light go on..... I was change my Air Flow Sensor and reset my ECC the light was off.On the next ignition CHECK ENGINE goes once more on...
So I try that several times... computer reset, ignition on , everythig fine, I was made 500 km without stop the motor , everything was suuuper.BVut when I turn the motor off und then once more On that light come on 5-10 sec. on.
Where is the reason ???????? What I can do ????
Please help !!!!!!!!!
Old Jan 13, 2002 | 02:15 PM
FTE Ken's Avatar
FTE Ken
The check engine light can indicate on of many conditions. Have you tried hooking up a code reader to see what the error condition is?
Old Jan 13, 2002 | 02:20 PM
lasertom's Avatar
lasertom
Hallo
I check it tommorow in service but in Poland is a little difficult find service for Explorers ... also I'm looking some help in EXPERT PLACE )))
Best regards
Old Jan 16, 2002 | 08:15 AM
larrycreed's Avatar
larrycreed
Hi
I have a '97 Eddie Bauer and just had my 'Check Engine' light come on and then go off after about 6 days. It has done this for quite a while now and I finally got it checked out at the dealer. They put it on the computer and found that my Oxygen Sensor was malfunctioning. This was causing the engine to periodically idle strange - the same symptoms that you are having. Engine will rev to 1000rpm for 2 seconds and then down to 400rpm for 2 seconds. Back and forth like this.
It's been a couple of weeks since they replaced the sensor and, knock wood, engine is idling normally.
Good luck,
Larry
Old Jan 16, 2002 | 10:53 PM
hankm's Avatar
hankm
yep... my guess would be oxygen sensor... remember that the
explorer has four of them too...
two of mine were bad... replaced them and cleared it right
up...
they're not cheap though... so be ready to shell out some
cash...
gl...
>forth like this.
Old Jan 17, 2002 | 01:31 AM
lasertom's Avatar
lasertom
Hallo all
The computer specialist could find the right size of socket to my diagnostic computer ( yes folks we are in Poland, its really away from YOU !!!!!!!!!!!!!!!!), so I couldnt read code errors , but i was bought original Oxygen sensor (they are not to expensive 1 pcs about 50 US Dollar) and coolant temp. sensor too (35$) I try to resolve this problem in thiss week and I give You all to know whats was next )))
I'm think my car had to many km. about 180.000 km and i think i must sell that and bay somethin ... what Do You think another Explorer or Doge Durango or RAM plise give some ideas.
I make about 10.000 km pro month
Old Jan 18, 2002 | 07:52 PM
hd1's Avatar
hd1
Do yourself a favor and keep the explorer,I sell autoparts for a living and if you hate money pits like I do,it's in your best and cheapest intrest to stay with the Ford!HD1
Old Jan 19, 2002 | 12:07 AM
lasertom's Avatar
lasertom
Thx Hd1 ) What do You think about Ford Expedition ????
Old Jan 19, 2002 | 05:59 AM
FortyFords's Avatar
FortyFords
xhrj001
Nov 19, 2016 06:22 PM
danger-dave
Bronco II
Jul 2, 2016 01:17 PM
yitzy
Aerostar
May 8, 2012 03:48 PM
dentoje
Dec 4, 2004 06:05 PM
swampler
Modular V8 (4.6L, 5.4L)
Oct 18, 2004 11:50 AM
