vacume at idle?
Old Jul 30, 2004 | 09:27 PM
79bronco300-6's Avatar
79bronco300-6
vacume at idle?
how much vacume at idle should a freshly rebuilt 300 I-6 have? just curious as i need to figure out what spring i need for my edelbrock.
Old Jul 31, 2004 | 10:10 AM
5_labsownus's Avatar
5_labsownus
If the rebuild was done corectly it should be 20 mm Hg
Old Jul 31, 2004 | 08:54 PM
srercrcr's Avatar
srercrcr
I'd vote 17.
Old Aug 1, 2004 | 12:25 AM
benwantland's Avatar
benwantland
It depends on your altitude and the cam in the engine.
Stock at sea level or within a couple of thousand feet should be about 20.
If you're significantly higher, vac may be a bit lower, and if you have a cam much over about 215* at .050, you'll start losing a little vacuum.
Old Aug 1, 2004 | 02:31 AM
optikal illushun's Avatar
optikal illushun
i was always told anywhere between 15-20 on a healthy engine was fine.
