1978 - 1996 Big Bronco
4WD question
Old Jul 30, 2004 | 08:30 PM
PeterM66's Avatar
PeterM66
4WD question
I had my 1990 Bronco with a 302EFI and 5 speed mazda tranny on a lift the other day. The truck was in 2 wheel High on the 4 wd shifter. I put the truck in gear and noticed the front driveshaft was spinning and also the front axles. The front tires were not since the hubs were not locked (manual hubs). My question is this: Is this normal or am I stuck in 4wd?
Old Jul 30, 2004 | 08:54 PM
BOJOFASO's Avatar
BOJOFASO
was the front shaft spinning the same speed as the rear shaft? ifso it is possible that you are stuck in 4x4. i would put it in gear with the engine OFF and see if i could spin the front drive shaft buy hand. if you are stuck in 4x4 you wont be able to turn the front drive shaft.
