03 Expy E/B A/C Condensate drain
Old Jul 29, 2004 | 09:32 PM
drivewizard's Avatar
drivewizard
While changing oil last night I noticed water dripping from above the Passenger side Cat. Upon closer inspection, I found that the water was seeping out above the heat shield over the cat. It was saturated between the shield and the bottom of the floor. It was not just a couple drops but amounted to about 1/2 cup, over the time that it took me to change oil.
The A/C has been working OK, my question is, where does the condensate drain from for the front A/C? I could not locate a drain hole, is it supposed to come out thru/around that heat shield? Seems like it would be a rust generator.
Old Jul 30, 2004 | 09:47 PM
cds's Avatar
cds
I know after driving our 2000 Expy EB, when is sits at a certain angle you can hear the water hitting the Cat, not a good idea cold water on hot metal. I guess that is another better idea by ford.
drivewizard
Jul 5, 2018 11:54 PM
Wolfboro
Apr 25, 2015 11:24 AM
pilgrimbizket
Apr 28, 2013 02:50 PM
blowhole
Jul 10, 2010 07:35 PM
blowhole
Jul 9, 2010 07:34 PM
