Boring and Piston Repl. for #2 Cyl.
Will boring and replacing piston and rings in just the #2 cylinder effect the compression ratio in that cylinder at all if a I use a stock type piston? The 240 in my '73 still has good compression in all the other cylinders and I can do the labor of pulling the engine out and taking it apart myself and a friend can bore the cylinder for me so I would be saving a lot of cash vs. rebuilding the whole engine, if this won't effect the c.r. by having a little more area to compress in that cyl. Also if I have the head rebuilt with valves for unleaded gas do you think this will help quite a bit too in restoring lost power.
I've seen big diesel inlines with one or more cylinders bored out and others still standard bore.
It's alot cheaper than to take metal off a perfectly good sleeve and be that much closer to resleeving a hole and they don't seem to need rebalancing even though not all of the pistons weigh exactly the same.
I would not do it my self. If I'm going to take the time to remove the motor and all the crap on the motor I'm going to do a full refab. New cam, ARP rod bolts, Forged pistons, Head work, all new bearings, and ect. I don't know how it would throw off the ballance to do one slug, since the weight would have to be diffrent. But hey that's just me.
Chris
Chris
