Tires
Old Jul 29, 2004 | 03:43 PM
Tranzmaan's Avatar
Tranzmaan
Tires
I know this doesnt have anything to do with 300 sixes, but I was wondering if someone could tell me what are the biggest size tires I could put on my truck with stock rims. Its a 88 F150 2wd. What size rims would I need for 33"s ? Thanks.
Old Jul 29, 2004 | 06:49 PM
couleeman's Avatar
couleeman
If they are 7.5" rims, I wouldn't go any bigger than a 33-10.5-15. Watch the size. Typically 33's are 33-12.5-15. I run 31-10.5-15 now but my next set will be a 33-10.5-15.
If you do go with the 33-12.5-15, watch the air pressure. You may find you have to run about 25psi or less to have them wear properly. usually the suggest 33's are run on 10" wide rims
Old Jul 31, 2004 | 12:01 PM
fordtradition's Avatar
fordtradition
31-10.50 it the largest size you can fit without rubbing. 32's will fit with some rubbing. 33's will rub badly. you will lose some load capacity and suspension travel with anything larger than a 31.
Old Jul 31, 2004 | 12:45 PM
GHog's Avatar
GHog
32X11.50 BFGs rub a little at full turn on 15X7 wheels.
abnmechny
Feb 26, 2013 08:50 PM
fossilX
Oct 29, 2009 05:41 AM
afonda
13
Nov 24, 2008 05:28 PM
goosedaddy61
1997 - 2003 F150
26
Oct 4, 2003 11:10 PM
AirKevin23
Sep 14, 2001 10:17 AM
