Trailer wiring help FAST PLEASE
Old Jul 29, 2004 | 12:00 PM
97_Ex's Avatar
97_Ex
I have a 97 expy and installed a 7 way plug some time back. I now have a enclosed trailer that needs a 12v constant source. In the factory harness that includes the electronic brake wire their is a orange wire that I was told was the one i needed but it has no power. The fuse under the hood is ok... WHATS THE DEAL?? PLEASE HELP, im leaving for a trip!!!!!!
Old Jul 29, 2004 | 12:03 PM
daveplot's Avatar
daveplot
The center pin should be the constant power. If you have a test light or circuit tester try testing it to see if your getting any power to that point.
I believe the truck must be on "on" for the power.
If you can't figure it out get some 10 gauge wire and run a fresh wire from the battery with an inline 30 amp fuse.
Old Jul 29, 2004 | 12:11 PM
HomerWinzlow's Avatar
HomerWinzlow
Seems like there is a relay that must be installed to make it work... cant remember for sure.
Old Jul 29, 2004 | 12:25 PM
97_Ex's Avatar
97_Ex
ok, it only works with the truck on, I guess it will work for this trip and then I will just run a new wire.... Thanks Guys
Old Jul 30, 2004 | 06:41 AM
scholzee's Avatar
scholzee
The center will not work for electric brakes they will always be on, a Ford dealer should be able to get you a harness to connect the brake controller to a plug under the dash. Then the brake controller signal will go to pin 3 on the factory mounted 7 pin connector.
# Color Gage Circuit Function connector interior
1 Black or Red 10 12v
2 Green 14 Right turn
3 Blue 12 Electric Brake
4 White 10 Ground
5 Small Yellow 14 Left Turn
6 Brown 14 Running lights
7 Yellow 10 Auxiliary 12v
NOTE: #7 is the center terminal and currently is most commonly used for backup lights.
Wiring Code 7 way Trailer End # Color Gage Circuit Function connector interior
4 White 10 Ground
Old Jul 30, 2004 | 06:28 PM
mcn420's Avatar
mcn420
The electric brake wire is blue, and if your X didn't have a factory trailer plug, just look where the main harness wires run, it plugs in somewhere around the spare tire. You'll see the blue wire doesn't come out. Just splic into it and you'll be fine.
As far as the battery charge wire. You'll be in the same situation as with the electric brakes, also it should only have power when the truck is on.
Consult your owners manual b/c there are 2 relays in the fuse box under the hood by the brake booster that need to be in place for either electric brakes or trailer battery charge wires to work.
