If and how can I wire in a AMP and Subs to my existing STOCK FORD Stereo System? I know absolutely nothing about car stereo, however, I have a killa' Home Theater Setup. Please HELP! LOL I'm sure there are more stupid questions I will be posting soon!
I have an '04 F350 Lariat that I put all new speakers in, 2 amps and a powered Bazooka tube in it all to the stock deck! Sounds awesome, only problem is the stereo shop installed it since I'm pretty clueless about electrical!! Can't help you with the install but it can be done.
Don't use the stock deck. You'd need to buy an fm modulator that goes to your fm signal and then has two rca'ss for te amps coming out of it. Buy a cheap aftermarket one, that has amp preouts. The sound quality will be much better
Price is no option, just want it to look good, I hate the look of those spacers........ Just Wondering, do those space leave a cubby hole open in the SD's? if so maybe get one customized and move my gauges there to fill th espace, just and ideal...............
You could always go with a deck that has the same DIN size as the stock deck... thereby eliminating any spacers or gaps. Plus a big increase in sound quality vs. going with the FM modulated system.
Go here... http://www.bestbuy.com/site/olspage....6&type=product This head unit should fit into the stock opening... so you won't have any gaps or need any adapters and crap like that. There are other head units that will fit into the opening as well... you just have to look at the manufacturers web sites or go to crutchfield.com. The size is called "Double DIN" just so you know. Also has all the features so you can expand your system in the future.. i.e. amps, subs etc... Hope this helps.
