I.r.s
Old Jul 29, 2004 | 06:51 AM
bootie's Avatar
bootie
I.r.s
anybody out there know much about fiting a jag rear end and as to how low it can go
Old Jul 30, 2004 | 06:50 AM
FortyFords's Avatar
FortyFords
Don't understand your ?
When installing a IRS suspension ,the lower arm must be level with the ground when all weight is on the vehicle.this keeps the u-joints in the middle of their travel for road bumps.
Rich
Old Jul 30, 2004 | 04:54 PM
bootie's Avatar
bootie
yeah got all that bit just curious as to what kind of ride height i can get it down to don't want to end up with the rear all jacked up and as to whether its been done before and what kind of results people had
Old Aug 2, 2004 | 04:35 PM
bootie's Avatar
bootie
anybody get any info on removing the cage from the jag unit and mounting it up ?
Old Aug 4, 2004 | 03:18 AM
35ford's Avatar
35ford
I fitted a Mark 10 Jag rear end to a 1935 Ford Pickup. I left the cage on the diff, and modified the rear section to remove some of the cage to allow the rear end to be seen. I made a channel crossmember, cut out the centres where the disc calipers intrude into the channel and bolted it to the chassis. So far everything fits correctly. I made traction rods out of tube, used tie rods to locate them in the same plane as the inner mounting points of the lower control arms. This keeps the correct geometry for the movment in the suspension. If you need any further information, please email me direct. fordparts@telstra.com
Ray M.
Old Aug 12, 2004 | 04:52 AM
bootie's Avatar
bootie
i'm gonna remove the cage in order to get the truck nice 'n' lo any body got any info or pics???????????
