Fuel Filter Change
Old Jul 28, 2004 | 11:01 PM
GoPokes's Avatar
GoPokes
Fuel Filter Change
I have a 2002 Explorer XLT with the 4.0 L. It has 42,000 miles so far. When do you recommend changing the fuel filter? I was thinking it might be a good ida pretty soon.
Thanks!
GoPokes
Old Jul 29, 2004 | 09:03 AM
jhromy's Avatar
jhromy
i have an 02 explorer and i get mine changed about every 15,000 miles...some people say that they never have to be replaced but im **** about everything being clean...the owner's manual states 15,000....get it changed it cost maybe $20.
Old Jul 29, 2004 | 03:06 PM
LV Dan's Avatar
LV Dan
I changed my filter recently after 30,000 miles of service as part of regular maintenance (no performance problems). I don't know how clogged it was, but a bunch of particulate material came out. I think I will change mine a little more often. I try to use better gas at newer stations, but dirt seems to get in anyway. I would say after 45,000 you are due for a new filter.
Old Jul 30, 2004 | 10:45 PM
GoPokes's Avatar
GoPokes
Many thanks!
Gentlemen,
Thank you for your responses. I appreciate it very much.
Talk to you later...
GoPokes
Old Jul 31, 2004 | 07:59 PM
mikephotos's Avatar
mikephotos
you guys do the change yourself or dealer? if yourself, any help on it's exact location (with pics?) and maybe a quick write-up on how you did it. my is overdue for a change and want to get to it....thanks in advance!
mike
Old Aug 2, 2004 | 03:37 PM
LV Dan's Avatar
LV Dan
Its easy to change yourself with a special tool available at most auto parts stores.
Read this thread:
https://www.ford-trucks.com/forums/s...e+fuel+filter+
The filter is located under the driver on the frame. You must go under the car on your back and look up to get to it. It is a round metal can about the size of a soda can with a hoses on each side.
