ok i have a 300 inline and i just got to the shore about 200 miles an it has a little sputter when i try to accelerate or just rev the motor. it kinda seems like it is running out of fuel but i have a half a tank. My gess is maybe a bad injector on one of the cylinders. the reason i am asking is cause i do not have the proper tools with me so i am asking for suggestions to eliminate the guess and check process. any and all help will be greatly appreciated.
Have you replaced the fuel filter and done a professional fuel injection cleaning service latel (Connect to Vacuum Hose, Throttle Body, Tank Additive)? Another simple thing would be to check ignition components, vacuum leaks.
if i pull the injectors myself what exactly should i be looking for if they would be clogged or anything else? right now i am at the beach and am very limited on tools.
